![]() | Home > Technical > help help injector spill rail |
When did you last have the fuel filter changed, you can get some fine stainless steel wire and lock it on with that, I have done a few in the past and they have all worked, but if you want to do the job properly then buy a new spill off pipe about £70.00 I think.
nicksrrs Member Since: 23 Apr 2014 Location: stourbridge Posts: 6 ![]() ![]() ![]() |
thanks for that ive decided to do that But why do they come off ??? |
They are bonded on and the glue just deteriorates and goes soft.
JOBS DONE !!! touch wood all,s well |
ho |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
I've just repaired my leaking spill rail but it was only the o ring, i refitted the plus and it blew back out throwing diesel everywhere. I bent the clip together before refitting and goofy wood it's been ok so far.
