Home > Technical > help help injector spill rail
nicksrrs
England 2005 Range Rover Sport TDV6 HSE Zambezi Silver
hi ive got an 05 tdv6 and its blown off the fuel spill pipe ive put it back on but it keeps blowing it off has anyone had this problem ?? the car is running great and starts first time every time . ive had the return levels checked and they are all more than they should be !! Sad Sad
Post #422603 Mon Apr 28 2014 2:26pm
flack
When did you last have the fuel filter changed, you can get some fine stainless steel wire and lock it on with that, I have done a few in the past and they have all worked, but if you want to do the job properly then buy a new spill off pipe about £70.00 I think.
Flack Thumbs Up
Post #422625 Mon Apr 28 2014 7:00pm
nicksrrs
thanks for that ive decided to do that But why do they come off ??? Thumbs Up
Post #422628 Mon Apr 28 2014 7:15pm
flack
They are bonded on and the glue just deteriorates and goes soft.
Flack Thumbs Up
Post #422631 Mon Apr 28 2014 7:25pm
nicksrrs
JOBS DONE !!! touch wood all,s well Thumbs Up Thumbs Up Thumbs Up
Post #422748 Tue Apr 29 2014 3:34pm
nicksrrs
ho Censored the spill rail is leaking again Sad Sad fitted genuine landrover and have done about 300 miles haven't changed fuel filter yet don't know where it fits ?? its on the left bank this time
Post #424213 Tue May 13 2014 7:08pm
RRS Daz
I've just repaired my leaking spill rail but it was only the o ring, i refitted the plus and it blew back out throwing diesel everywhere. I bent the clip together before refitting and goofy wood it's been ok so far.
All the engine not getting out back together till I'm confident it's holding good.
Post #424215 Tue May 13 2014 7:26pm
