Home > Maintenance & Modifications > New Air Compressor |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
From other threads hereabout, that does appear to be the case, yes. They also need to replace the relay in the fuse box too - I believe it comes with the new compressor. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 28 2014 11:32am |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
hi, not all require the update. Relay yes. Mine didnt need it and works fine. |
Mon Apr 28 2014 1:01pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
The compressor will work, as is, out the box. All the software does is write out the motor temperature reading in the ECU, as the new AMK doesnt have said sensor.
Mon Apr 28 2014 2:18pm |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
Thanks for the feedback guys - It's been booked in at LR as a 'Whilst you wait' job £60
Mon Apr 28 2014 2:51pm |
