Home > Maintenance & Modifications > New Air Compressor
Sag
New Air Compressor
Hi Guys,
Dad is having his Air Compressor replaced as it failed a couple of weeks ago. Went in to a private garage this morning who are doing it and was told it needs a software update from LR for the compressor to work?
Is this correct?
The car is a 2006 (55) HSE.
Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #422582 Mon Apr 28 2014 10:44am
From other threads hereabout, that does appear to be the case, yes. They also need to replace the relay in the fuse box too - I believe it comes with the new compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #422586 Mon Apr 28 2014 11:32am
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
hi, not all require the update. Relay yes. Mine didnt need it and works fine.
Post #422595 Mon Apr 28 2014 1:01pm
Disco_Mikey
The compressor will work, as is, out the box. All the software does is write out the motor temperature reading in the ECU, as the new AMK doesnt have said sensor.
But, on some cars, the light will come on due to no temperature reading, and some are fine.
Post #422602 Mon Apr 28 2014 2:18pm
Sag
Thanks for the feedback guys - It's been booked in at LR as a 'Whilst you wait' job £60
Post #422609 Mon Apr 28 2014 2:51pm
