Home > General > Stablity Problem
futureian
2006 Range Rover Sport TDV6 SE Buckingham Blue
Stablity Problem
My RRS is more unstable than I think it ought to be. I was driving along a 2 mile straight siiting at 60mph when the near side of the vehicle hit a slightly lower area of road. In other cars that I drive you would feel the lower area on the road but the motion of the car would not be affected. On this occasion the vehicle stepped out towards the centre line of the road (the driver of a vehicle coming in the opposite direction must have wondered what was going on).
What is going on? I have had it to the garage and although some wear on the bushes of the rear arms was noted it was deemed not enough to cause what happened. The car has 22" wheels (were on the car when I bought it). I have reduced the tyre pressures and this has helped a bit but it still feels a bit erratic if you hit an undulation in the road. The mechanic figures it is a combination of slight wear in rear bushes, tyre pressures too hard (now lowered to 34/30) and wide wheels.
Any other ideas - Would standard 19" wheels help?
Post #422421 Sat Apr 26 2014 10:03pm
speedy2009
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Is it like it's tram lining ?
Post #422428 Sat Apr 26 2014 10:52pm
tailormadefun
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
My 2006 is the same, I've had it checked and it's all good so I guess it is one of those RRS peculiarities
Tmf
Post #422446 Sun Apr 27 2014 6:35am
Disco_Mikey
Re: Stablity Problem
22" wheels tend to be wider, and will be a lower profile than standard sizes, and as such, will pull, and tramline more than those on 19"-20" wheels
Any play in suspension bushes will also affect it.
That, and some of the roads up in Scotland can be pretty shocking...
If you have access to another set of wheels, I would try them first Thumbs Up
Post #422447 Sun Apr 27 2014 6:56am
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
19"wheels would make a massive difference,but wouldnt look half as good Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #422448 Sun Apr 27 2014 6:57am
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
I had a similar problem the back would step out slightly at 30mph on local roads whilst going over a small bump or little ditch in the road. Had the alignment done all sorted now. Maybe worth while getting that checked first maybe.
Post #422461 Sun Apr 27 2014 8:58am
futureian
Yes, on occasions that is what it can do.
Post #422518 Sun Apr 27 2014 6:25pm
futureian
Tram lining – Yes, that is what it can do.
The wheels were aligned just before I bought it. I reckon I might need to bite the bullet and try some 19’s. I can always sell them on if it doesn’t improve things.
Post #422519 Sun Apr 27 2014 6:33pm
