![]() | Home > Technical > Gear Indicator |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Are you in auto then it will only show a small D. To get the car to show which gear your in you need to be in command shift and select the gears manually 2008 G4 RRSport TDV8 current
Guernseygeordie Member Since: 16 Apr 2014 Location: St Peter Port Posts: 10 ![]() ![]() ![]() |
Cheers guys, didn't really make that clear in the manual!
