Home > Technical > Gear Indicator |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
welcome to the forum - welcome to the Supercharged club you will get 'Sport' show up on the display when you push the gear selector to the left - you will then get the gears shown when you use command shift 16MY Estoril Blue SVR.............
Fri Apr 25 2014 9:06pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Are you in auto then it will only show a small D. To get the car to show which gear your in you need to be in command shift and select the gears manually 2008 G4 RRSport TDV8 current
Fri Apr 25 2014 9:07pm |
Guernseygeordie Member Since: 16 Apr 2014 Location: St Peter Port Posts: 10 |
Cheers guys, didn't really make that clear in the manual!
Fri Apr 25 2014 9:36pm |
