![]() | Home > Maintenance & Modifications > Replacing existing door tread plates |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
What have you got - the whole of the plastic trim with the inserts or just the polished inserts ? 16MY Estoril Blue SVR.............
Topgeartowers Member Since: 18 Mar 2014 Location: London Posts: 48 ![]() ![]() |
Hi Peachy,
As you have stated the outer plate should come off easy but the warmer the better - if needed use a hair dryer on the plate this helps agitate the adhesive. Finger power should be enough - take your time. When I replaced mine I replaced the whole trim plastic which came with the inner plates inserted already. Do the named - inner plates have clips or adhesive - I'm sure they are clipped - There are 2 ways - either remove the whole trim which is easy enough or just the sill plate ( I've never done it that way ). By removing the whole trim you can get a better grip on the plates both taking off & replacing.
Thanks so much for taking the time to write all that out - much appreciated mate.
Tgt - pm sent |
simonk Member Since: 20 Apr 2014 Location: Rotherham Posts: 46 ![]() ![]() ![]() |
Did you manage to get the inner plates out of the plastic ok?
I took the plastic sills off, but the attached stainless steel part wouldnt budge. So I've bought replacement bog standard plastic trim from LR (£21 per side) and will attach the new stainless steel covers to them instead. |
