Home > Technical > active cruise control
michiuk
England 2006 Range Rover Sport Supercharged Bonatti Grey
Hi ,just been out in my rangey and got on dual carriage way pressed the button but no cruise control tried all buttons the only one that worked was the active gap distant control as any one got any ideas please
Post #420470 Sun Apr 06 2014 5:23pm
PEACHY
Start at the beginning - has it worked - or have you tried it before Thumbs Up 16MY Estoril Blue SVR.............
Post #420474 Sun Apr 06 2014 5:32pm
michiuk
Hi Peachy, every thing was perfect the last time I used cruise control about 10 days ago
Post #420476 Sun Apr 06 2014 5:35pm
PEACHY
Shocked never had the problem - it seems a few have Big Cry
http://www.rrsport.co.uk/forum/post285467.html
Use the search function to search possible solutions - I have the same model so if you need me to check anything pm me & I will send you my number Thumbs Up 16MY Estoril Blue SVR.............
Post #420478 Sun Apr 06 2014 5:41pm
PEACHY
Do you have the original steering wheel fitted & can you feel the resistance - click when you use the switch packs ? 16MY Estoril Blue SVR.............
Post #420479 Sun Apr 06 2014 5:49pm
PEACHY
A mate had a disco with the same problem - just spoke to him - he ended up changing the clockspring Big Cry 16MY Estoril Blue SVR.............
Post #420480 Sun Apr 06 2014 5:53pm
Andi
May be obvious, but were you in sport mode?
Post #420484 Sun Apr 06 2014 6:25pm
myfirstrrs
Does it not work in sport mode Andi?
Post #420485 Sun Apr 06 2014 6:29pm
Andi
Well it doesn't on mine (2010 model) only in ordinary drive. Thumbs Up
Post #420486 Sun Apr 06 2014 6:38pm
myfirstrrs
I haven't tried in mine but this will save me panicking if I do try.
Post #420487 Sun Apr 06 2014 6:40pm
PEACHY
Shocked well I didn't know that - slippers on - I'm out for a test drive Rolling with laughter Bow down Bow down 16MY Estoril Blue SVR.............
Post #420488 Sun Apr 06 2014 6:40pm
Andi
That's what happened to me, no matter what I did I couldn't get the CC to work, then when I stopped and went to put it in park I realised I was in sport. Went back out, and CC worked perfectly. Embarassed
Post #420489 Sun Apr 06 2014 6:50pm
PEACHY
Just drove a couple of miles down dual carriageway - went from D - to SPORT mode with cruise on - worked - I then put it into Command Shift - again it stayed on - even used the gap button with no problems at all. Tried it the other way round putting it straight into SPORT then setting the CC - again no issues Shocked 16MY Estoril Blue SVR.............
Post #420492 Sun Apr 06 2014 6:56pm
Andi
Now that's weird, just tried to look at manual online through topix but the sites not working properly. The Freelander manual says don't use in sport mode.
So, mine doesn't and yours does peachy...maybe mine was just playing up that day, never tried it since!
Post #420493 Sun Apr 06 2014 7:00pm
Re: active cruise control
When you say that active distance control worked do you mean the one that is associated with cruise control or the one controlled by the button on the centre console?
If the one on the centre console works but not the rest of it then I would suggest that the brake switch might need changing. 2012 SDV6 - it's missing a couple of cylinders
Post #420494 Sun Apr 06 2014 7:02pm
