![]() | Home > Technical > active cruise control |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Start at the beginning - has it worked - or have you tried it before |
michiuk Member Since: 11 Oct 2013 Location: Bristol Posts: 9 ![]() ![]() ![]() |
Hi Peachy, every thing was perfect the last time I used cruise control about 10 days ago |
Do you have the original steering wheel fitted & can you feel the resistance - click when you use the switch packs ? 16MY Estoril Blue SVR.............
A mate had a disco with the same problem - just spoke to him - he ended up changing the clockspring |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
May be obvious, but were you in sport mode? |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Does it not work in sport mode Andi? |
Well it doesn't on mine (2010 model) only in ordinary drive. |
I haven't tried in mine but this will save me panicking if I do try. |
That's what happened to me, no matter what I did I couldn't get the CC to work, then when I stopped and went to put it in park I realised I was in sport. Went back out, and CC worked perfectly. |
Just drove a couple of miles down dual carriageway - went from D - to SPORT mode with cruise on - worked - I then put it into Command Shift - again it stayed on - even used the gap button with no problems at all. Tried it the other way round putting it straight into SPORT then setting the CC - again no issues |
Now that's weird, just tried to look at manual online through topix but the sites not working properly. The Freelander manual says don't use in sport mode.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
When you say that active distance control worked do you mean the one that is associated with cruise control or the one controlled by the button on the centre console? If the one on the centre console works but not the rest of it then I would suggest that the brake switch might need changing. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
