Home > In Car Electronics > Adding tv tuner |
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 |
Hi jay, I didn't think of that I could use my iPhone 4g then and link to ipad if it is possible , will look into all this tomorrow and get some prices of everything I need , I have one of the tesco tablets knocking around here somewhere may do a dummy
Sat Mar 15 2014 9:59pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
You do know if you have the gvif unit,with a £4.99 lead you can watch anything from your iPhone on the standard screen. |
Sun Mar 16 2014 12:12pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
Oh link to the correct iPhone to gvif would be good.
Sun Mar 16 2014 12:59pm |
Ok so many possibilities , what would you all do ? Basically I want the cheapest and tidiest option, I have an iPhone 5 with unlimited Internet download data , I have sky go linked to the phone and drove around today with it on all works fine, so now I want to view on main screen or add tablet and view through that , what would you guys do ? And what would I need to do it , rich |
Sun Mar 16 2014 5:49pm |
I thinking the original screen pixels etc wont be good enough ? |
Mon Mar 17 2014 9:01pm |
Plenty good enough,if you want Hd stay at home |
Mon Mar 17 2014 11:24pm |
chelseablue06 Member Since: 06 May 2013 Location: united kingdom Posts: 26 |
If Sky go is the main reason only option in my opinion is an IPad mini. It fits over the existing nav unit if you want a less hassle install but you will need to cut the left vent for the charger cable.
Mon Mar 24 2014 9:49pm |
Ordered all the bits now just wondered why does new aux with Bluetooth adapter need to be in glove box , is there a reason or can I put the Bluetooth somewhere else . Rich |
Tue Mar 25 2014 9:05pm |
TonykRRS Member Since: 30 Jul 2013 Location: London Posts: 7 |
I thought I'd just give a bit of a plug to Nick from Aftermarket Vehicle Accessories, who supplied and fitted a reverse camera and TV tuner for just over £500. I didn't fancy taking the job on myself!
Fri Mar 28 2014 2:17pm |
Hi Rich
Fri Mar 28 2014 8:32pm |
Hi jay, yes got it all but not happy with Bluetooth at mo as sound is a lot quieter than normal stereo, don't know if the Bluetooth adapter I got is not up to the job as it was just a cheap one . Rich |
Fri Mar 28 2014 9:14pm |
I will try to dig out the details of the one I got off ebay. It was cheap but works perfect although you do need to make sure the tablet volume is up fairly high. If going above 30 on the volume dial there is a slight interference sound which i think is down to the cheap electrics in it. This can be removed by adding a ground loop adapter in between the Bluetooth adapter and the aux socket, or as my wife would say by not listening to music that loud
Fri Mar 28 2014 9:44pm |
Thanks jay |
Fri Mar 28 2014 9:45pm |
