Home > In Car Electronics > Adding tv tuner
chelseablue06
2006 Range Rover Sport TDV6 HSE Buckingham Blue
Hi Rich
Yes you can get a 3G/4g version of the samsung however I went down the wifi only route. When my mobile phone connects to the car Bluetooth it automatically turns on the internet sharing feature and shares this with the samsung tablet. This means I only have the one cost for my phone contract which includes unlimited 4g tetherting. I managed to get the 8.0" version of the samsung tab 3.0 for £149 from tesco direct just after Christmas.. The 4g version was around £320 at the time.
I use spotify for music and tunein radio for all my digital radio channels. For Tv I use catchup tv for freeview streaming, the Bt sport app occasionally and an application called Dvb link for any other satellite channels. Dvblink requires all sorts of extra hardware at home to allow the streaming so it's not worth doing unless you already use this for home Tv as we'll.
As far as I'm aware sky go is iPad only so that may sway your choice. Very Happy
I have also installed the Rosen rear entertainment system and through this I can stream films/tv to the rear headsets using an airplay receiver (raspberry pi) connected to the Rosen unit.
Keeps the kids quiet and allows me to watch the football when on a long drive (providing the wife agrees to drive of cause!) Laughing
Post #417895 Sat Mar 15 2014 9:27pm
rich_z3
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi jay, I didn't think of that I could use my iPhone 4g then and link to ipad if it is possible , will look into all this tomorrow and get some prices of everything I need , I have one of the tesco tablets knocking around here somewhere may do a dummy
Run with it see how it goes, rich
Post #417898 Sat Mar 15 2014 9:59pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
You do know if you have the gvif unit,with a £4.99 lead you can watch anything from your iPhone on the standard screen.
Post #417920 Sun Mar 16 2014 12:12pm
RRS Daz
Oh link to the correct iPhone to gvif would be good.
I use the aux input to listen to music as that's all I thought I could do.
Post #417925 Sun Mar 16 2014 12:59pm
rich_z3
Ok so many possibilities , what would you all do ? Basically I want the cheapest and tidiest option, I have an iPhone 5 with unlimited Internet download data , I have sky go linked to the phone and drove around today with it on all works fine, so now I want to view on main screen or add tablet and view through that , what would you guys do ? And what would I need to do it , rich
Post #417951 Sun Mar 16 2014 5:49pm
rich_z3
I thinking the original screen pixels etc wont be good enough ?
Post #418131 Mon Mar 17 2014 9:01pm
mrfixit
Plenty good enough,if you want Hd stay at home Laughing Thumbs Up
Post #418153 Mon Mar 17 2014 11:24pm
chelseablue06
If Sky go is the main reason only option in my opinion is an IPad mini. It fits over the existing nav unit if you want a less hassle install but you will need to cut the left vent for the charger cable.
Teather to your iPhone and no need for an extra data connection Smile
If you run a new aux to the top glove box fit a Bluetooth adapter and the quality of the audio from the IPad is much better especially if listening over 25 on the volume.
I mornings work and you won't regret it Smile
Post #419065 Mon Mar 24 2014 9:49pm
rich_z3
Ordered all the bits now just wondered why does new aux with Bluetooth adapter need to be in glove box , is there a reason or can I put the Bluetooth somewhere else . Rich
Post #419198 Tue Mar 25 2014 9:05pm
TonykRRS
Reverse Cam + TV tuner supplied & fitted
I thought I'd just give a bit of a plug to Nick from Aftermarket Vehicle Accessories, who supplied and fitted a reverse camera and TV tuner for just over £500. I didn't fancy taking the job on myself! Exclamation
Nick is based in Wolverhampton, but has done work all over the place. He's a nice, honest guy and did a great job.
I actually took my Sport to him, which was a bit of a trek from where we are in NW London, but we had a (erm) nice day out and in the end it was more cost effective to get the cam & TV fitted this way.
You can contact Nick on 07544 404556
http://www.yell.com/biz/aftermarket-vehicl...n-7554027/
Post #419532 Fri Mar 28 2014 2:17pm
chelseablue06
Hi Rich
You can place the Bluetooth adapter anywhere I chose the glove box as it was close to the extra aux port I ran from the passenger footwell. I also had a 12v power supply in there for the tablet anyway so it was perfect.
Has your stuff arrived for fitting now?
Post #419576 Fri Mar 28 2014 8:32pm
rich_z3
Hi jay, yes got it all but not happy with Bluetooth at mo as sound is a lot quieter than normal stereo, don't know if the Bluetooth adapter I got is not up to the job as it was just a cheap one . Rich
Post #419579 Fri Mar 28 2014 9:14pm
chelseablue06
I will try to dig out the details of the one I got off ebay. It was cheap but works perfect although you do need to make sure the tablet volume is up fairly high. If going above 30 on the volume dial there is a slight interference sound which i think is down to the cheap electrics in it. This can be removed by adding a ground loop adapter in between the Bluetooth adapter and the aux socket, or as my wife would say by not listening to music that loud Whistle
I'll send you a Pm with the details of the adapters
Jay
Post #419584 Fri Mar 28 2014 9:44pm
rich_z3
Thanks jay
Post #419585 Fri Mar 28 2014 9:45pm
