![]() | Home > Maintenance & Modifications > REVERSING CAMERA - WITHOUT GVIF? |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
if I were you, I would buy the camera and see if this can be connected directly. although i have been informed that a video interface is required (i.e. there isn't one built-in). there are some tech savvy guys on this forum and I'm sure they would have solved this had it been possible. but try to prove them wrong |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 ![]() ![]() |
Many thanks for the reply Luke. I am fairly sure nothing else is needed - I think the video interface which is only needed if you do not have the TV/Satnav is the GVIF. I have got a camera and I just need the connector for the display to try it out.
Peanut, it only works automatically if you put the touchscreen into FFRR mode by cutting one of the wires on the back of the screen.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
^^^^^^^^^^^^^^^^^^^^^ your alive |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
As Bodsy says you need to be in FFRR mode for this to work. I've tried it and found it to be unreliable and giving problems elsewhere with the touchscreen interface so reverted back to the standard RRS mode.
