Home > Maintenance & Modifications > REVERSING CAMERA - WITHOUT GVIF?
Peanut
I have spent some time researching the various posts on this and the Disco & FFRR site but would appreciate confirmation (or otherwise!).
We have a 2007 MY 2.7 HSE luckily fitted with Satnav, Freeview TV and DVD player.
As far as I can see a GVIF is not needed as the screen has a Fakra/SMB socket to take a camera input which when enabled in CCF will automatically switch on reverse to display the camera. I have an IID tool so whilst I have not yet ventured into the CCF this looks simple enough. The camera to be powered from the reverse light connection.
Am I correct?
If so can someone confirm the connector and specification for the camera? NTSC/PAL? etc.
I believe the forum has a suitable connector available?
Post #418968 Mon Mar 24 2014 11:19am
tanloverluke
if I were you, I would buy the camera and see if this can be connected directly. although i have been informed that a video interface is required (i.e. there isn't one built-in). there are some tech savvy guys on this forum and I'm sure they would have solved this had it been possible. but try to prove them wrong Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #418992 Mon Mar 24 2014 1:43pm
Peanut
Many thanks for the reply Luke. I am fairly sure nothing else is needed - I think the video interface which is only needed if you do not have the TV/Satnav is the GVIF. I have got a camera and I just need the connector for the display to try it out.
And some advice on changing the CCF!
Post #419164 Tue Mar 25 2014 4:32pm
Bodsy
Site Sponsor
Peanut, it only works automatically if you put the touchscreen into FFRR mode by cutting one of the wires on the back of the screen.
You can connect the camera and it will work, but only if you put the screen into diagnostics mode to rest the video connector.
Or you can install a gvif...... Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #419217 Tue Mar 25 2014 10:49pm
PEACHY
^^^^^^^^^^^^^^^^^^^^^ your alive Bow down Bow down 16MY Estoril Blue SVR.............
Post #419219 Tue Mar 25 2014 10:58pm
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
As Bodsy says you need to be in FFRR mode for this to work. I've tried it and found it to be unreliable and giving problems elsewhere with the touchscreen interface so reverted back to the standard RRS mode.
Other than the GVIF route you may want to consider a rearview mirror with integrated monitor, I've installed one and it works great and looks very OEM.
It's a bit cheaper than a GVIF unit but doesn't offer the functionality... So you pay your money and make your choice.
Here's the link to my 'write-up' on the mirror.
http://www.rrsport.co.uk/forum/post404648.html#404648
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #419226 Wed Mar 26 2014 6:14am
