![]() | Home > General > e a s control |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/Range-Rover-Spor...35d381cb60
is it a good piece of kit peachy |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Pm sent |
I went for the lowering arms rather than the electronic unit. Also seems to work well and don't get any errors.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
I'd go for it's big brother the IIDTool. It has the EAS functionality but also gives access to other systems on the RRS. WOrks well and I reckon you'd get one for not much more than the cost of the EAS tool. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
The full IID is around �100 more, but gives the option to update various modules, as well as CCF editing, read/clear fault codes, service reset etc
any links to the iid tool plesase |
Try this - http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...4897.l4276
http://www.island-4x4.co.uk/integrated-int...27513.html
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Hi fkarim, Could you please clarify "set TTM before alignment"? Why would this save dealer costs twice a year? Forgive my ignorance but I am trying to learn these things before I pick the car up next week. |
orangevanman Member Since: 18 Mar 2013 Location: Nottingham Posts: 145 ![]() ![]() |
please forgive my ignorance but what does this actually do? |
myfirstrrs: The Sport's suspension needs to be put in tight tolerance mode (TTM) before wheel alignment. This helps in setting up the geometry more accurately as the air suspension works harder than normal (less tolerant to height differences between the 4 corners) to keep the car level.
If you opt for the Bluetooth module (highly recommended BTW |
Thanks fkarim, sounds like I should try to get the dealer to do this before I collect the car, at least to know that it is right to start with.
