Home > Technical > RRS Transmission Fault
djacko
United Kingdom 2006 Range Rover Sport TDV6 HSE Siberian Silver
Just after some help....
few weeks ago my range lost power from gearbox after coming up with transmission fault, after been towed home and scanner plugged in it came up with torque converter solenoid stuck and also incorrect gear ratio...i was advised to change transmission fluid and sump filter which i have done and i got it up to temperature last night and topped it up as stated.
Everything was working spot on even the acceleration response was better. After about 30 mins and a few miles it suddenly came up with HTC special programmes off then transmission fault. Then struggled to get car back onto ramp without putting foot to floor and it felt like it was slipping in every gear.
Has anyone else had a similar or the same problem any help is better than no help
thanks.
Range Rover Sport 2006 2.7 TDV6 HSE
Post #418239 Tue Mar 18 2014 1:15pm
Disco_Mikey
Is the cable stiff to move?
djacko wrote:
...it came up with torque converter solenoid stuck and also incorrect gear ratio...i was advised to change transmission fluid and sump filter which i have done and i got it up to temperature last night and topped it up as stated.
Does it change gear smoothly, or is it jerky/banging when it changes gear?
Post #418355 Tue Mar 18 2014 7:18pm
djacko
Doesnt feel stiff and after fluid change drove perfect into every gear no noises bangs or thuds
Post #418430 Wed Mar 19 2014 12:37pm
Disco_Mikey
When the oil change was carried out, did they reset the adaptive values?
If so, the car needs to be driven within a certain range of parameters to relearn its gear positions/ratios Thumbs Up
Post #418435 Wed Mar 19 2014 1:09pm
djacko
I drained the fluid and changed it myself following instructions from range rovers technicians instructions so only took sump filter off and replaced with new after fluid drained out
Post #418438 Wed Mar 19 2014 1:27pm
Disco_Mikey
Did you use normal red ATF to refill the box?
Post #418444 Wed Mar 19 2014 2:20pm
djacko
i used to red gearbox oil part number tyk500050...thats what i was advised to get
Post #418447 Wed Mar 19 2014 2:37pm
