Home > Technical > RRS Transmission Fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Is the cable stiff to move?
Does it change gear smoothly, or is it jerky/banging when it changes gear? |
Tue Mar 18 2014 7:18pm |
djacko Member Since: 18 Mar 2014 Location: Lincolnshire Posts: 5 |
Doesnt feel stiff and after fluid change drove perfect into every gear no noises bangs or thuds |
Wed Mar 19 2014 12:37pm |
When the oil change was carried out, did they reset the adaptive values?
Wed Mar 19 2014 1:09pm |
I drained the fluid and changed it myself following instructions from range rovers technicians instructions so only took sump filter off and replaced with new after fluid drained out |
Wed Mar 19 2014 1:27pm |
Did you use normal red ATF to refill the box? |
Wed Mar 19 2014 2:20pm |
i used to red gearbox oil part number tyk500050...thats what i was advised to get |
Wed Mar 19 2014 2:37pm |
