Home > General (L494) > Performance of the SDV6 with On/Off road pack vs. SDV8
Page 1 of 3 123>
DBA
Macedonia
Hi All,
Can someone that has the SDV6 engine with On/OFf road pack (Dynamic Response, TR 2, Torque vectoring, Hi/Lo range..) sure the experience in terms of performance in the real world driving, such as overtaking?
I am curious since, it seems that this pack adds quite a wheight to the vehicle, since the SDV8 for example, which includes this pack, weighs almost 300 kg (around 600 pounds) more then the SDV6. Don't believe the SDV8 engine is so much heavier?
The V8 supercharged petrol is around 200 kg more (~400 pounds).
I would like this pack, in order to decrease the roll in corners as much as possible as well as want to have a no-compromise off-road system, but I am bit afraid that if I opt for this pack on a SDV6 it might make it a bit sluggish?
Post #418415 Wed Mar 19 2014 9:05am
PauloAmore
Scotland
Doesn't fee; sluggish....
Feels almost as quick as my 4.2 petrol, previous model.
defo fast enough; IMHO 2022 P440e AB
Post #418417 Wed Mar 19 2014 9:23am
Tboner
See other area's on the forum , lots of info SDv8 V SDV6
I am lucky to have both and SDV8 is a long way in-front of the SDv6 esp in real world 30-50 50-70 Over takes etc.
Fuel consumption again real world 2-3 MPG diff at most as you do not hit the peddle as hard in the V8 v the V6
And yes you are correct the weights are all wrong when you start adding up the extra's, the engine is just 80 Kilo's i am told not the stupid numbers that are quoted from a Bogo SDv6 with nothing on it, Even my wife who has the 3.0 has used my SDv8 405 and comments on the diff between the 2 engines as massive ! SDv8 with the suspension changes over the V6 make it a far more involving drive and all round performer. 2014 5.0SC AB
Gone 5.0 SC
Post #418425 Wed Mar 19 2014 11:21am
DBA
Macedonia
Thanks for the feedback!
I also found this article which agrees with the conclusion that the SDV6 is a bit underpowered (With the on/off road pack as well):
http://www.carmagazine.co.uk/Drives/Search...re-review/
Post #418426 Wed Mar 19 2014 11:49am
The hi/low range transfer box adds 15kg to the overall weight of the RRS. The other bits won't add a huge amount more.
As for Car Magazine saying it's not fast enough, others seem to think otherwise:
http://www.autocar.co.uk/car-review/land-r...erformance 2012 SDV6 - it's missing a couple of cylinders
Post #418434 Wed Mar 19 2014 12:49pm
DBA
Macedonia
Hmm... But if the hi/lo range is just 19 kg and torque vectoring is just a software.
Adaptive dynamics and dynamic response I would assume is composed of just some sensors and software.
Not sure how the locking differentials are implemented...
So how come the SDV8 is almost 300 kg heavier and supercharged petrol 200 kg?
I also noticed that the fuel tank is bigger on 8 cylinder machines, but that is something like 30 liters more.
Also about the AuoCar review as I understood their car is without the on/off road pack and the CAR magazine was equipped with it.
Post #418436 Wed Mar 19 2014 1:20pm
Where are you getting the 300kg difference from? At launch, several reviewers quickly pointed out that the weights quoted by LR were way out. There was a big thing made about the new RRS being 400kg lighter than the old one. It is if you choose to compare the old S/C or TDV8 and new TDV6 with no kit. The reality is that the new RRS is not hugely lighter than the old one in most trim engine/trim packages.
I'm still of the opinion that the on/off road pack doesn't add more than maybe 25kg to the mass of the RRS (15kg for the transfer box and maybe 10kg for additional sensors / trick rear diff). 2012 SDV6 - it's missing a couple of cylinders
Post #418441 Wed Mar 19 2014 1:59pm
DBA
Macedonia
The SDV8 is rated at 2398 kg as opposed to 2115 kg for the SDV6 (so 283 kg heavier), in the official Land Rover tech. specification documents:
http://newsroom.jaguarlandrover.com/en-in/land-rover/tech-specs/
Post #418442 Wed Mar 19 2014 2:12pm
Tboner
work out were the weight changes are that is the point of the posting made it's not the weight of the engine as a whole ! Even the press release there is wrong on the 4.4 suspension Sad not shocked of course ! 2014 5.0SC AB
Gone 5.0 SC
Post #418445 Wed Mar 19 2014 2:29pm
Note that it says weight "from" and then the figure. I believe the SDV6 doesn't get down to that weight in reality because it has higher spec (more kit such as multi-movement seats etc. and all of that adds weight) than the base weight (which was the bsaic SE version). 2012 SDV6 - it's missing a couple of cylinders
Post #418449 Wed Mar 19 2014 3:29pm
mse
The weight reduction isn't really a reduction though...they removed all the bits and made them optional to make a big deal that the car was lighter than previous version and for emissions etc
Add the toys back on its comparable to the last sport. Mike
2014 Facelift Discovery
Post #418452 Wed Mar 19 2014 4:51pm
Tboner
Yeah Ha - Exactly - only if you buy a bog standard Se comparable model with no extra's will you get that kerb weight
It's all marketing BS 2014 5.0SC AB
Gone 5.0 SC
Post #418464 Wed Mar 19 2014 5:18pm
mse
indeed Exclamation
Anyone can remove a diff and save Xkgs! Mike
Post #418469 Wed Mar 19 2014 5:36pm
Renaco
More Power ist There, more sound also. But Power is not everything.
For me the main concern is the V8 adds more than 100 kg to the front arches, this changes the Balance of the car negative to the old FWD Feeling.
Thats the reason why LR delivers,the car only with all the adaptive dynamic etc, to recover this as much as possible.
I drove all of them, and for sure with all the Engines the Drive is better than with the Diesel V8.
If V8, Petrol, thats Power, Sound and the RRS in the right Balance.
Just my personal feel after testing them, and i owned 8 FFRR and 2 RRS.
Post #418481 Wed Mar 19 2014 7:40pm
SVR575
Renaco are you saying the sdv6 diesel is the best diesel or get the SC. SVR 2018 in Santorini Black.
Post #418482 Wed Mar 19 2014 7:49pm
Page 1 of 3 123>
