![]() | Home > Technical > OFF ROAD MODE ? |
When you say off road mode, do you mean low ratio box or do you mean sand mud ice etc settings? |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
you mean the GPS offroad function?
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 324 ![]() ![]() ![]() |
Thanks for coming back! What I am trying to do is find the Co-ordinates of the area I am parked in - I am staying on various campsites in Spain and need the reference to get me back to the site after being away for a while. Andrew Kennedy |
Thanks for coming back. I am sure that is the way I have found it in the past but for some reason is not working at the moment?!? Andrew Kennedy |
Take your disc out of the unit under the passanger seat, then put it back in and see if it reboots itself. |
Thanks for your advice......PROBLEM NOW SOLVED.....the re boot worked!! Andrew Andrew Kennedy |
