Home > Technical > OFF ROAD MODE ?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
OFF ROAD MODE ?
I have a 2006 Sport. Usually I go to 'off road mode' with the GPS Voice Recognition (but it's not working at the moment). I cannot find how to go to Off Road Mode manually?!? Can anyone tell me how this is acheived Andrew Kennedy
Post #418041 Mon Mar 17 2014 9:49am
When you say off road mode, do you mean low ratio box or do you mean sand mud ice etc settings?
Post #418045 Mon Mar 17 2014 9:56am
jochem00
you mean the GPS offroad function?
pressing the left of the the two buttons below the screen should do it.
Post #418046 Mon Mar 17 2014 10:00am
andrew kennedy
Thanks for coming back! What I am trying to do is find the Co-ordinates of the area I am parked in - I am staying on various campsites in Spain and need the reference to get me back to the site after being away for a while. Andrew Kennedy
Post #418050 Mon Mar 17 2014 10:23am
andrew kennedy
Thanks for coming back. I am sure that is the way I have found it in the past but for some reason is not working at the moment?!? Andrew Kennedy
Post #418052 Mon Mar 17 2014 10:27am
Take your disc out of the unit under the passanger seat, then put it back in and see if it reboots itself.
Post #418056 Mon Mar 17 2014 11:10am
andrew kennedy
Thanks for your advice......PROBLEM NOW SOLVED.....the re boot worked!! Andrew Andrew Kennedy
Post #418187 Tue Mar 18 2014 9:46am
Post #418188 Tue Mar 18 2014 9:51am
