![]() | Home > In Car Electronics > Bluetooth update in RRS 2005 - Anyone in London location |
Hiya,
davies435 Member Since: 09 Jan 2014 Location: Slovakia (long story) Posts: 11 ![]() ![]() ![]() |
Ian,
Do you have red and green button on the right hand of the steering wheel....? I suspect you don't have and therefore don't actually have the Bt module. They all have the phone button on the radio if that's what your going by I'm afraid.
futureian Member Since: 28 Dec 2013 Location: Scotland Posts: 22 ![]() ![]() |
Bodsy,
correct, no green/red buttons on the steering wheel.......expensive to retrofit this kit? Mike |
You need a disco4 BT module (you can use a disco3 one but similar price), most cable, steering wheel switches, microphone if you don't have it already.
Bodsy, you had me with you right up to the word "fitting"...FTW came after? This one of those "going to have to get violated by main Stealer anyway" things???
Torx 20 screwdriver, a flat blade screwdriver, a posed rive screwdriver and some crimps or solder, no hammer required.
Ned Kelly Member Since: 03 Mar 2014 Location: Great Yarmouth Posts: 12 ![]() ![]() ![]() |
Hi All, I am having the same problem with my 2006 RRS. I can connect my phone but have to do this every time I start the RRS up. I have spoken to the local dealer and he has said there are no updates for the RRS???? |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Ned, speak to the bodsy. Plug and play module. This will solve your problem. No more 2121. |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 ![]() ![]() ![]() |
mine does the same with my new Nokia but not with my lumina 800 ? |
Thanks Bodsy, that works and was a simple fix |
Unclebuck Member Since: 04 Dec 2014 Location: South Yorkshire Posts: 51 ![]() ![]() ![]() |
Hi, I'm in South Yorks and desperate to get this Bluetooth upgrade as I'm fed up of putting 2121 before it connects ! Can anyone help ? Thanks |
I can help |
