Home > Maintenance & Modifications > Tdv8 decat and remap
scottc1088
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Java Black
Iv recently bought a 07 tdv8 and im looking at removing the cats and getting a remap, where do people get their decat pipes from as I cant seem to find them anywhere
same for the remap as well really, who do you recommend?
Post #417885 Sat Mar 15 2014 8:45pm
If you remove the cat then it will fail its mot, and if vosa catch you without it fitted they will impound your car and give you a hefty fine. Remap is the only way to go. Thumbs Up See site sponsor BAS here. http://bellautoservices.co.uk/
Post #417891 Sat Mar 15 2014 9:14pm
scottc1088
I know the law, I own an mot station Laughing
is there a supplier for decats that people use? if not ill make my own but that means cutting mine up which isn't ideal if I want to put it back on
also does anyone remove the egr valves? or is it generally done in a map?
thanks
Post #417912 Sun Mar 16 2014 10:08am
SRE
Spain
Loads of info on this and the Disco 3 Forum, best bet use the search function on both Forums then make your own mind up.
Personally for a remap I would use Pete Bell or J E Engineering.
http://bellautoservices.co.uk/ is a site sponsor In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #417914 Sun Mar 16 2014 10:45am
RRS Daz
The egr delete isn't possible on the tdv8 as far as I know.
Post #417924 Sun Mar 16 2014 12:55pm
By rights then, you know better. Whistle Risking you livelihood for a few extra horses really isn't worth it is it Question
Post #417936 Sun Mar 16 2014 4:12pm
What will you do come mot? Put it back on?
Post #417983 Sun Mar 16 2014 8:31pm
RRS Daz
I would of thought he would mot it himself?
Post #417988 Sun Mar 16 2014 9:21pm
If he does Daz, then that could be his downfall should he get tugged. His signature on his own mot certificate. Embarassed
Post #417990 Sun Mar 16 2014 9:36pm
RRS Daz
Granted true but a test certificate is only a true record of the vehicle on that given time and date.
A good example is a tyre that passes an mot but then the driver goes and does a burn out , then gets pulled by the police and done for a worn tyre. True story Whistle
But even if he put the cat on then wrote a certificate out and then removed it, you are right should know better Rolling with laughter
Now the cat has to be present on the mot has the construction and use act been changed to reflect it or has it always stated it should be there?
Post #417995 Sun Mar 16 2014 9:59pm
Camelrock
There's nothing to stop you MOTing your own cars, been doing mine for years, don't have a choice as I'm the only tester/mech in the garage. The boss lets me do them for free so I'm not going to go somewhere else and pay £50 for someone else to do it 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #417999 Sun Mar 16 2014 10:37pm
I agree, but my point is, as you know what the mot standards are and you deliberately break the law as in Scott's case, he intends to, should he get caught, and then vosa find out who mot'd his car, it will open a can of worms at the mot station where he works and then questions get asked what else is slipping through the net at this particular mot station. Whistle I guess he is running one of the so called "friendly" mot stations that vosa are clamping down on.
Post #418027 Mon Mar 17 2014 8:31am
