![]() | Home > General > Parking sensor inactive..... |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Sounds like a sensor has failed - they don't last forever & are battered daily by the elements |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
Thanks Peachy.
I had mine read by a diagnostics tool - pinpointed the exact sensor that was out - it may be a loose wire or connector - unfortunately it's a bumper off job, which is easy if your that way inclined.The only problem is the fasteners underneath become a little brittle over time & tend to break.
Thanks again dude.
Here you go - |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Hi mate. Easy way to find the faulty sensor is sit in car engine running foot on brake obviously and activate the sensors is be close enough to anything that would make them work. Get your mate or Mrs to put there ear to each sensor and you will hear a clicking noise. The one that doesn't click is faulty..PS don't run anyone over |
You guys are great!
Your welcome but if you take the bumper off & it's a sensor what you gonna do then |
Pm me if u need one I have a spare new one |
I'll check to see if they are all clicking first.....
gazzc - would you recommend changing all 4 that way it's a job done once & once only |
To be honest peachy I don't really know |
......ahhhh....well, my RRS is Stornaway Grey as is the bumper but the sensors are in the bottom black plastic part and are black. |
Perhaps mine is just a wire?.... |
