![]() | Home > Maintenance & Modifications > Alternator or battery problem?!? (or both!) |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
First I'd find out if the battery is draining because something is pulling power from it when the car is off. A new battery or alternator won't fix a "current leak".
Mattyp1 Member Since: 03 Oct 2012 Location: London Posts: 10 ![]() ![]() |
This is probably wishful thinking, but I changed rear brake bulb before all this started happening! Just a halfords one, surely that can't cause all this!..the bulb hasn't blown or anything though, does anyone know the correct battery for rrs 2.7 2006.. Spec etc, thanks so far mrfrog |
Believe it or not, brake bulbs have been responsible for gearbox faults amongst others. I have Bosch bulbs from Halfords, a little more expensive than the halfords branded ones and no problems. Might be worth an upgrade if you have the cheap o es before shelling out on new battery, etc....
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Check the button for the upper tailgate, it corrodes and provides a path for the battery to drain, just had to replace mine, and it is an known problem with MY07/08 vehicles Sons of dogs come hither and get flesh
tonycash27 Member Since: 25 Aug 2013 Location: Sevenoaks Posts: 26 ![]() ![]() ![]() |
Agree check upper tailgate , heard of this often and anywhere else in this area where water can get in |
