Home > Technical > Black rear quarter light trim fell off on motorway |
Kklone Member Since: 02 Jul 2013 Location: Kings Lynn Posts: 53 |
Would it be possible to semi permanently fix the panel using some automotive grade adhesive such as stixall?. is there a need for the panel to be removable?.
Tue Feb 25 2014 2:48pm |
SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127 |
Not sure what I could glue it to - it seems to clip to the rear of the glass panel with felt spacers holding it off the metal bodywork behind. Anyway, a picture...
Tue Feb 25 2014 3:58pm |
just did an image search for Range Rover Sport rear trim panel clips, have a look and see if any of them look like your clips. Perhaps they are worn if they keep coming adrift at speed, I have had a similar thing happen with an engine under tray and the only solution was new clips.
Tue Feb 25 2014 4:17pm |
Is this any help?.
Tue Feb 25 2014 4:21pm |
Seems as though you need something like this.....
Tue Feb 25 2014 4:27pm |
Yes - very, very helpful - thank you very much.
Tue Feb 25 2014 4:28pm |
I'm not sure if the trim for the later sports is the same as the early ones, but a quick google of range rover sport d pillar trim returns some results if you click on images.
Tue Feb 25 2014 4:36pm |
I stand corrected ( By myself ), they will paint them any colour you want.
Tue Feb 25 2014 4:38pm |
Okay - I have just removed the studs and whole trim and one of the four front tabs (lower middle) that locates under the glass was bent back on itself. I guess this was done when it was built - instead of locating the clips under the glass panel the idiot building it just gave it a hard knock, bending one of the tabs that wasn't aligned properly.
Tue Feb 25 2014 4:50pm |
No problem, you're very welcome.
Tue Feb 25 2014 4:54pm |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
you may find that this will still come away some time in the future. This happened to mine. The 'lug' or clip which is integral to the moulding becomes weaker once bent initially, and then just gets weaker and weaker. Then the other lugs start to bend. The only solution I found was to replace the whole thing with a new one, and luckily I got a new one on ebay for £25 delivered. RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Wed Feb 26 2014 9:27am |
