Home > Technical > Pull to the right on acceleration
nharris
Hi All.
I've just taken delivery of a 2010 face lift RRS with 30k Miles. Everything is well except that i've noticed that it pulls to the right, quite dramatically, on acceleration. I've test driven a friends for comparison and his does this ever so slightly, but nothing to the extent of mine. Is this a characteristic or is there a problem? I've already sent it back to the dealer once for vibration at the wheel and this was solved by a re-balance.
Any help very welcome!
Cheers,
Nick
Post #415348 Mon Feb 24 2014 7:55pm
Huw
Wales 2008 Range Rover Sport TDV8 HST Stornoway Grey
Hi Nick,
Had a similar problem with mine after I bought it from land Rover dealer. Had serious torque steer and vehicle was pulling to the right. Problem was vehicle was 20mm lower front and back on the offside than the near side and was down to the suspension height sensors on offside which was sorted out under warranty. If not sorted will cause abnormal tyre wear.
Huw Range Rover Sport 3.6tdv8 HST,110XS Puma Defender Double Cab,90XS Defender, 2 Discovery 3s, 3 Discovery TD5s,Defender V8 50 (should have kept!!), Discovery 300, Freelander (big mistake!!), Range Rover Classic 3.9
Post #415394 Tue Feb 25 2014 8:59am
I'd start off with a simple alignment check up (about £50). Thumbs Up
Is there any uneven tyre wear too Question
Find a place near you www.alignmycar.co.uk Wink
RRS's are renowned for losing alignment over time (mine even came from the factory on the Censored Rolling Eyes ). I had mine done twice in 2 years Confused ON THE WAY: BMW F21 M140i
Post #415395 Tue Feb 25 2014 9:06am
