Home > General > headlight washer not working |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Bumper off to get to the washer pipes - if there's a puddle could just be as simple as pushing the pipe back on - I've taken many front bumpers off - piece of - the only real problem you may have is the retaining bolts under the front bumper - these may break - my advice - if you are hands on have a go but start with the bolts underneath first if they break you will then need another plan drill out the remaining part of the bolt or pay someone & let them have the pain. Wheel arch lining is a DIY job again some fixings may break but they are cheap - I think the lining is less than £30.
Fri Feb 21 2014 12:58pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Taking the front bumper off is ten minute job and easy for DIY man with bit of savvy 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Feb 21 2014 1:01pm |
AlanEricThompson Member Since: 14 Oct 2013 Location: Nuneaton Posts: 96 |
Thanks lads, will have a go when weather warms up !! 3.0 HSE RRS Stornaway (current)
Fri Feb 21 2014 5:13pm |
