Home > General (L494) > Max Speed on a RRS SC |
SDV6RRS Member Since: 08 May 2013 Location: Hampshire Posts: 52 |
Did you check it wasn't your passenger making the whining noise? 2014 MY RRS HSE Dynamic
Tue Feb 18 2014 10:41pm |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
And is it limited to that speed, 250kph, same as is widely used in Mercedes? Mark
Wed Feb 19 2014 6:58am |
hornbaek Member Since: 11 Dec 2013 Location: Richmond Posts: 39 |
Mark, As mine is a very early SC (June 2013) is it possible that you can expand a bit on your observation, as this might be the case with my car. |
Wed Feb 19 2014 7:45am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1671 |
Wasn't there a recall to do with the front wheel arch liners or something? Maybe this. |
Wed Feb 19 2014 9:37pm |
So the LR dealer is being characteristically useless. However, your contract is with them, so they should at least be able to get some guidance from LR where there will at least be some experience of driving the car at higher speed. It is a pity you couldn't get an audio recording; that was the way I solved a fuel pump problem with my SL55 AMG. Incidentally, when you brought it back from Germany, did you come on Eurotunnel and if you did, did you use the normal car coaches or the ones designed for cars with roof racks which have usefully extra width between the wheel damaging kerbs. Mark SVR in Estoril Blue |
Thu Feb 20 2014 6:25am |
I used the roof rack option - so no problem with width. |
Thu Feb 20 2014 7:47am |
Yes, I think that's the best by far. I'm asked from time to time by the Eurotunnel JobsWorths why I booked that way when I turn up in something which doesn't need the height and they get a flea in their ears. Mark
Thu Feb 20 2014 7:55am |
You actually don't need to book the roof rack option. When you approach the 1.85 barrier there is an escape route for cars higher than 1:85 and you simply take that route and that will automatically put you in one of the high carriages. |
Fri Feb 21 2014 7:39am |
True but I had my fingers burned when I turned up without booking and found they were fully booked in the tall coaches so had to wait. I also wonder whether every train has tall coaches. Mark
Fri Feb 21 2014 9:35am |
I got my car back from Guy Salmon service today where it had been in for the whining noise at 135 mph. There is a service bulletin out saying that it is due to the windscreen/roof seal which has now been changed on my car. Obviously i have not had a chance to check it but GS was quite adamant that this was the solution to the problem. |
Fri Feb 28 2014 8:21pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Good info! Does that mean the dealers are going to road test every new RRS at 135mph before deciding whether to renew the seal? |
Fri Feb 28 2014 8:27pm |
Mine is an early SC (June 2013) so my guess is that later cars have this sorted already. |
Sat Mar 01 2014 3:24pm |
