![]() | Home > Technical > TDV6 Broken Crank |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
Had an RRS recovered in on Monday morning, with a broken engine.
The pics are a bit hard to see but I assume it is the old spun bearing then seize issue. Is it the main bearings that are seizing or the big end bearings seizing. Also is there any particular bearing (which position) where the failure occurs and does the crankshaft snap in the same place.
East Coast Sport Member Since: 23 Jul 2013 Location: Angus Posts: 78 ![]() ![]() ![]() |
Looking at the pictures and admittedly its a bit hard to see, but the patterns in the broken section look like a classic case of brittle fracture.
67k mlies. No service book in the car
The crankshaft journals and bearings were immaculate. No scoring etc whatsoever. It looks like plain and simple failure, with no evidence to suggest lack of maintenance, overheating etc... |
Well that is interesting - structural defect - that is a worry.
