Home > General > Upper tailgate microswitch falls out!!! |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
The tailgate microswitch is secured by the 2 plastic moulded tabs - nothing else - if you ever need to remove it - the safest way is to remove the trim ( 8 torx screws ) & release from inside - I found out the hard way & broke a tab - had to replace the whole switch ( it was corroded anyway ) £28 to replace from a stealer As for the arms mine is very light to lift. 16MY Estoril Blue SVR.............
Mon Feb 10 2014 10:55am |
HandsomeWeasel Member Since: 07 Jan 2014 Location: Hertfordshire Posts: 37 |
ive only had it 2 days, so ive bitched to stratstone to have the problem sorted.
Mon Feb 10 2014 11:04am |
After this short a period of ownership get the 'hydraulic" units changed along with the switch under their warranty !!
Mon Feb 10 2014 2:10pm |
