![]() | Home > Faults & Fixes > Upper Tailgate Switch. |
Perhaps - since the RRS electronic are supposed to shut down completely about 15 or 20mins after the ignition is switched off the partial circuit of the tailgate switch is continuously detected and the various ECUs don't then turn off and the car stay 'live' eventually flattening the battery. |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
the contacts corrode inside giving a signal of open tailgate which drains your battery |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Took the switch out & it looks like brand new inside no rust or condensation |
for the price of a new switch i would just change it |
tatterz Member Since: 16 Dec 2013 Location: bucks Posts: 13 ![]() ![]() |
How can you access the switch to change it?
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
You have to remove the cover. Open the upper tailgate to get at the screws from the inside. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Hally Member Since: 07 Oct 2013 Location: Hartlepool Posts: 24 ![]() ![]() ![]() |
I recently changed out my tailagte switch on a 2006, just removed the rubber cover from switch and prized it out with a screwdriver. HALLY |
