![]() | Home > Maintenance & Modifications > HELP!! EGR valve replacement - Torx screw |
I take it you've undone the three longer bolts holding the EGR to the engine block? If not, undo those and access is easier with a bit of leverage.
Daddyjcool Member Since: 11 May 2012 Location: England Posts: 15 ![]() |
Hi Bodsy
Glug glug glug |
Cheers, will have a crack at that too.
Did you get it sorted? Bodsys Brake Bible
Hi Bodsy
