Home > General > Unusual behaviour
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Unusual behaviour
Hi folks- any help much appreciated.
Just started the car which has been unused and in the cold for around 2 weeks. On start the front end dropped and then rose again, in a controlled way as if I'd pressed access mode and back to normal. I then noticed smoke streaming out from underneath the engine, visible underneath the front spoiler- is that the pre heat thing? Then when I switched off quite a definite buzzing noise, from where unknown, for about 30 seconds. Any help?
Post #411856 Thu Jan 30 2014 4:23pm
sounds like the fuel burning heater to me for the smoke
though the dropping and raising doesn't sound right, maybe over time the air had leaked out and it needed to re compress the gases, i would see how that goes and check for leaks if it happens again
Post #411858 Thu Jan 30 2014 4:28pm
Russben
Buzzing noise sounds like the Fuel Burning Heater. The FBH fan runs for a while after you stop the engine to dissipate the heat.
Not sure about the front end dipping though. It could be it had settled a bit while standing & reset itself after you started it up. I'm in the shed, I'll be back in the real world in a minute.
Post #411874 Thu Jan 30 2014 5:56pm
mse
FBH for the smoke - but it could be some power blip and the air suspension reset for a moment.
More of an issue if it does it again Mike
2014 Facelift Discovery
Post #411878 Thu Jan 30 2014 6:02pm
Bomber H
Another in agreement re: the buzzing and smoking being the FBH Thumbs Up
As for suspension, mine hasn't done that, so as suggested I would just monitor it. 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #411879 Thu Jan 30 2014 6:03pm
Bladeboy
Thanks for the replies. Just got me home no problem so hopefully it was just upset that it hasn't been used
Post #411884 Thu Jan 30 2014 6:11pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
It's normal for the RRS's suspension to adjust itself if it hasn't been driven for a few days, mine does the same thing. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #411901 Thu Jan 30 2014 7:09pm
Bladeboy
Thanks Jaz
Post #411923 Thu Jan 30 2014 10:31pm
