Home > Technical > Front suspension risng slower than normal (pointers please)
Paul Holywood
Hello All
I have noticed after a couple of days of no use, the front is sitting very low (both sides).
and recenly the car rear comes up very quickly, but the front can take almost 15 seconds.
There also is a red indicator flashing display before i turn ignition on, representing the front height sensors are registering low, but clear when it rises, no other indication or warning lights ?
Today i started the motor and sat for about three minutes before tying to raise to standard height, and again the car lifted very quickly from the rear (i presume using the tank for the rear suspension) and the compressor for the front.
my question is what should i be concentrating reading up on for a fix?
1) Possible air leaks
2) Compressor
3) Air valves
4) something i have missed
Many thanks in advance Wink
Post #411227 Sun Jan 26 2014 8:47pm
Paul Holywood
Been reading many past threads and i think i may look at the Dryer first.
does anyone know where and how to access the front air valve?
as i would like to strip this down as well..
Post #411249 Sun Jan 26 2014 9:44pm
Any other symptoms Paul Question Dodgy battery/alternator Question
Post #411253 Sun Jan 26 2014 10:19pm
Paul Holywood
No Ady, other than one of the little red height indicators flashing from the front right, and when i try and access off road height i get a message "suspension rising slowly" thats it.
but due to compressor running and getting hot i expect that message anyhow, so im not worried about off road height adjustment.
its rising from access to standard thats getting slower, that is my issue.
Ive read almost every thread, but i get conflicting answers.
The slow rising seems to be one issue, but the leaking over night is pointing another..?
Post #411255 Sun Jan 26 2014 10:36pm
flack
You need a new Compressor normally with this error, but others have got away with the dryer. The front air valve is under the drivers side wheel arch cover at the front just behind the fog light.
Flack Thumbs Up
Post #411257 Sun Jan 26 2014 10:55pm
Paul Holywood
Front end leaking doesn't sound like compressor to me, but I wait to be told otherwise. Whistle
Post #411329 Mon Jan 27 2014 3:09pm
Logic tells me that if its a leak, then the air is coming out almost as fast as its going in, hence the time its taking to raise the front end. Whistle
Post #411331 Mon Jan 27 2014 3:20pm
Paul Holywood
I dont think its as bad as that (hopefully) Shocked last night i left it at standard height, the front had dipped a small amount this morning, but after a few second of engine running the front went up very quickly, again the back was already up, so i gather the compressor only had to pump up the front only.
please dont get me wrong im learning as i go here, im happy to buy a new compressor just as long as it is the correct part to be replaced. Thumbs Up
Post #411343 Mon Jan 27 2014 5:46pm
Mine is slow to raise the front end if I ask it to do so soon after starting the engine. Given a few minutes of running, however, it tends to be a lot quicker. A drop and immediate re-raise will be slow again. It points to a tired compressor - I must get around to getting mine changed too. 2012 SDV6 - it's missing a couple of cylinders
Post #411359 Mon Jan 27 2014 7:10pm
Paul Holywood
How Bazaar..
Today its been absolutely fine, lifts up just after the rear is fully up.??
confused.com Rolling with laughter
Post #411515 Tue Jan 28 2014 7:40pm
drdelrrs
I don't supposed you noticed whether its worse on very cold weather - just wondering if the dryer has allowed moisture in system which has almost or fully frozen and is restricting airflow ?
Post #411575 Wed Jan 29 2014 10:06am
Paul Holywood
Good point, yes coincidentally it was 2 deg when it was slow that morning, and yesterday it was very mild, and worked fine..
Post #411591 Wed Jan 29 2014 12:04pm
drdelrrs
Paul - The forecast over the next few days is for 'brass monkey' weather - even in Herts- so you might be able to be able to see if it occurs again and if there's a cold weather pattern.
Post #411594 Wed Jan 29 2014 12:11pm
Paul Holywood
Now you've planted that seed, i will be watching, cheers for your help Thumbs Up
Post #411595 Wed Jan 29 2014 12:14pm
Paul Holywood
Been spot on every day so far????
Post #412064 Fri Jan 31 2014 9:38pm
