Home > Technical > Heated Rear Window |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
I wonder does anyone know if the rear window heater comes on automatically at low temperatures? I know it seams a silly question but, now its colder up here, mine (2012 model) seems to switch on and off on its own. there is no indication at the switch. I know it comes on when you start at low temperatures but the warning lights on the switch illuminate. The only reason I think it comes on is the area adjacent to the heater wires tend to become more obvious in the spray for a while then disappear and cycle.
Thu Jan 23 2014 4:01pm |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
Have the same on mine but then it does show it is switched on. I will monitor this in the next few days
Thu Jan 23 2014 5:52pm |
essexfarmer Member Since: 28 Aug 2011 Location: Essex Posts: 108 |
Mine does it too, as Hugh says it's more obvious when the window has spray on it, on mine it almost seems like it's working on low power as it does not clear/dry the window completely iit just clears around the wires. 12MY RRS Orkney Grey HSE Lux
Thu Jan 23 2014 6:27pm |
Exactly right Essexfarmer it seems to be at a lower power since I have tried it actually ON and the effect seems faster. There is nothing I can find in the handbook. I suppose it could be thermal conduction in the metal wire but it seems stronger than that. Well to me at least.
Thu Jan 23 2014 7:38pm |
