![]() | Home > Maintenance & Modifications > Best polish/wax for Santorini Black with a few scratches... |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Poorboys Black hole
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 ![]() ![]() ![]() |
For the scratches use this - Farecla 7163 150ml G3 Professional Scratch Remover Paste
CMLE Member Since: 03 Jan 2014 Location: Shropshire Posts: 48 ![]() ![]() ![]() |
Thanks Dhups and npinks, will give those a try!
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
G3 is a compound, best used with a machine polisher.
^^^ Generally Farcela produce compounds to be used with a machine, but the product above is part of their consumer range and is for application by hand |
^^^^ That doesn't surprise me Mr Bean |
Same here, not sure why I don't use blackhole |
Its definately worth a try guys, |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
I tried Black Hole once - never again, too messy. |
Yep - I applied it by hand and it came with a applicator pad. Not used the Black hole product so can't compare. But I'm sure both will do a good job ![]() |
TST717 Member Since: 09 Sep 2012 Location: INVERNESS, Posts: 165 ![]() ![]() |
Seems to be 2 different topics on here!
looks like the two recommendation, has lead to a discussion on pros and cons of each to me |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 ![]() ![]() |
Poorboys black hole is a glaze not a polish or a wax. It will fill in a lot of the scratches but will not remove them. Handy until you get time to polish and then wax if and when it stops raining.
