![]() | Home > Technical > No throttle response |
EGR valve |
greyheadgit Member Since: 21 Oct 2013 Location: Lincoln Posts: 13 ![]() ![]() |
Disco-Mikey
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Had the same problem, egr valves blanked off and problem solved. Be careful not to round off the soft alloy bolts if blanking off the valves.... |
Thanks for the advice. Do I leave the valve connected when blanked off or what.
You've got two options, leave everything connected and install blanking plates, should be about £8, or buy a kit that enables you to remove some components and hoses, cost about £50. From what I can gather there is no difference performance wise, it's just that some people prefer to de-clutter the engine bay if components are not needed, though this option foes involve a little more work. If anyone else knows otherwise please share the knowledge |
As above |
As above but get the mapping checked after as removing/blanking off can change what the engine requires in fuel. 2x TDV6. SE and HSE. Both returned to sender with issues👀
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
I have been reading with interest these posts regards EGR vLves, if it is so common place to blank off or remove these why are they fitted in the first place ?. Surely they must perform some worthwhile function... Maybe one of the more knowledgeable can explain |
As the title says, exhaust re circulation. They basically feed the engine the exhaust gas at low revs/idle to Reburn gases which will contain particles of diesel. It is a way for manufacturers to get engines to conform to Euro5 spec engine emissions. Works great in theory, just not so well with modern sulphur free fuel that clogs up systems with Black Death carbon. Only countries that require these by law are Holland and Switzerland. Hope this helps |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Just remember EGR'S can't be blanked off on RRS 2007> onwards. 2014 L405 SDV8 RR Autobiography |
i knew someone would enligten me ! |
Where are the 8 quid ones from and where are the 50 quid ones from as only seen the 50 quid ones on ebay. |
Apologies for being technologically challenged but I don't know how to post the link, but if you type 'tdv6 egr blanking' into the eBay search bar you'll find a selection for under £10. There is a set from staffs 4 x 4 for £5 with free delivery.... |
Thanks Tony, I will get on it so that I can get the damn things fitted this weekend as its driving me nuts at present. |
