Home > Maintenance & Modifications > 105k maintenance
stebenny
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
105k maintenance
Hi everyone, I have a RRS HSE 2007 97,000 miles, I have been told that i when i reach 105,000 miles i have to have some work done that is expensive, Do i have to have this work done our are you just advised to, Thanks Steve..
Post #409233 Sun Jan 12 2014 7:21pm
tanloverluke
if you're referring to the cam belt and oil pump housing, it'll probably be more expensive by not having them done. and think about the re-sale value Thumbs Up by having them done in time. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #409234 Sun Jan 12 2014 7:25pm
stebenny
Thanks for your help, It was the cam belt have you any idea of cost, Thanks Steve
Post #409237 Sun Jan 12 2014 7:29pm
It depends what you have been told that needs doing. If you have been told that you need the cambelt replacing, then you have been given the correct information, and yes you really do need it doing or face the risk of destroying your engine if its not replaced and your old one snaps. Big Cry With the service and all the belts that need replacing from an indi garage you are looking at around £600 ish.
Edit, must type quicker. Embarassed
Post #409238 Sun Jan 12 2014 7:30pm
drdelrrs
All service plans are suggestions which you can ignore.
However if you have any sort of warranty 'they' will insist maintenance complies with LR's recommendations.
Obviously reliability can suffer and there can be safety considerations; IF you had a serious accident that resulted from a component failure that should have been changed/maintained then you could have a problem - but if the car passed its MoT its a mute point.
Its a fact that because many cars are basically reliable loads of drivers never do any checks especially on new cars and those not yet not subject to an MoT; its no accident that expensive cars less than 3 years old are often the ones that have their mileages computer 'adjusted'
Post #409239 Sun Jan 12 2014 7:31pm
tanloverluke
one thing i've heard through this forum is that the cost can be lessened if you source the parts yourself, e.g through one of the site sponsors, then pass these on to the lr garage or indie for fitting. or you could do the entire job yourself, if you dare. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #409249 Sun Jan 12 2014 8:29pm
stebenny
Thanks all for your help, I have not been told that the work needs to be done by a garage just a lad in the pub told me about it, tanloverluke thanks for that, I just about know how to drive and were the fuel goes so i think i will start saving up and let the garage do it. Laughing
Post #409251 Sun Jan 12 2014 8:47pm
