Home > Maintenance & Modifications > 105k maintenance |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
if you're referring to the cam belt and oil pump housing, it'll probably be more expensive by not having them done. and think about the re-sale value by having them done in time. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Sun Jan 12 2014 7:25pm |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 |
Thanks for your help, It was the cam belt have you any idea of cost, Thanks Steve |
Sun Jan 12 2014 7:29pm |
It depends what you have been told that needs doing. If you have been told that you need the cambelt replacing, then you have been given the correct information, and yes you really do need it doing or face the risk of destroying your engine if its not replaced and your old one snaps. With the service and all the belts that need replacing from an indi garage you are looking at around £600 ish.
Sun Jan 12 2014 7:30pm |
All service plans are suggestions which you can ignore.
Sun Jan 12 2014 7:31pm |
one thing i've heard through this forum is that the cost can be lessened if you source the parts yourself, e.g through one of the site sponsors, then pass these on to the lr garage or indie for fitting. or you could do the entire job yourself, if you dare. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Sun Jan 12 2014 8:29pm |
Thanks all for your help, I have not been told that the work needs to be done by a garage just a lad in the pub told me about it, tanloverluke thanks for that, I just about know how to drive and were the fuel goes so i think i will start saving up and let the garage do it. |
Sun Jan 12 2014 8:47pm |
