Home > Wheels & Tyres > TYRE WEAR PROBLEM |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
I presume they checked wheel geometry?
Fri Jan 10 2014 8:34am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Agreed. A four-wheel alignment check is called for. Ideally, the alignment should be checked off a datum on the chassis, otherwise, it is possible for the wheels on an axle to be aligned with each other, but not with the chassis (eg steering not in the neutral position when going straight), causing the car to go crabwise.
Fri Jan 10 2014 9:07am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 324 |
Hi there Paul. Many thanks for getting in touch re my tyres. I haven’t had the wheels geometry, but I will when I return to the UK. The car is on its second set of tyres and the present ones have only been on for 10/15,000 miles (no problems with the first set), however, I have been towing a light weight caravan although I do keep the back pressures up when towing – I don’t take much notice of ‘nose weight’ - could that we causing a problem?!? When I purchased the present tyres I looked round for the best deal – are there inferior tyres on the market that I could have got fobbed off with? What do you think? Andrew Andrew Kennedy |
Sat Jan 11 2014 3:07pm |
Andrew
Sat Jan 11 2014 3:55pm |
Thanks Paul. I will check nose weight in future. In live in France and the local RR garrage feels my problem could be faulty types?!? Is it possible I could have been sold inferior types i.e. they have Continental on the side walls but are they the real deal. Andrew Kennedy |
Mon Jan 13 2014 11:06am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Many on here have had problems with Contis and LR issued guidance to dealers
Mon Jan 13 2014 2:16pm |
Very many thanks for that......that's solved by concern. I'll change them as you suggest. Andrew Andrew Kennedy |
Mon Jan 13 2014 4:54pm |
