Home > Maintenance & Modifications > TDV6 alternator replacement
Black Bess
The alternator has died on my 2005 RRS. I have arranged supply of a new unit, but looking at the job, access is a bit tricky.
Has anyone done one of these before?
Do you attack it from above, removing the fan shield and intercooler trunking? or do you go in from below after removing the engine shields?
I am just hoping somebody else`s experience will save me time.
Thank you
Adam..
Post #408816 Thu Jan 09 2014 11:06am
mdcbigdave
Site Sponsor
Hi Adam,
I had mine go on my TDV6 Disco,
from the top chap, its fairly straightforward as long as you can get your fan off.
It requires a special tool to hold in place while you tap off the nut counter clockwise.
Once that's off just slip off the drive belt (and maybe replace while your there) and swap out alternators.
An hour tops if the fan comes off.
Mine didn't and was a nightmare.
Best of luck.
Dave
Thumbs Up All things transport and logistics, international and national shipping.
Its a small planet after all.
info@md-couriers.co.uk
Post #408819 Thu Jan 09 2014 11:55am
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
alternator removal
the job isnt that straightforward if you have the Dynamic response package fitted
Post #408847 Thu Jan 09 2014 4:23pm
Black Bess
Thanks, but I don`t think I have dynamic response on mine. What does it look like?
Adam..
Post #408924 Fri Jan 10 2014 9:09am
mdcbigdave
Site Sponsor
Adam,
I think I got a bit of info wrong.
The nut for the fan comes off CLOCKWISE im sure.
Best check with someone who knows these things!!
Dave
Post #408930 Fri Jan 10 2014 9:39am
Black Bess
Thanks Dave. Viscous fans are usually LH thread, so i was prepared for that. I have the new unit now, so i just need to fathom my route in to remove the old one. Smile
Access around the V6 engine is a bit of a challenge!!
Adam..
Post #408941 Fri Jan 10 2014 10:50am
Shaun75750
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Did mine just before Christmas it's a really
Easy to do I followed the how to on the
Disco 3 site
Post #408961 Fri Jan 10 2014 1:25pm
mdcbigdave
Site Sponsor
Ive got the special spanner somewhere if you want it? All things transport and logistics, international and national shipping.
Post #408966 Fri Jan 10 2014 2:20pm
Black Bess
Thanks. I am planning to tackle it next week and may have to improvise on the special spanner front. If I get stuck I will have to let you know.
Adam..
Post #408974 Fri Jan 10 2014 2:52pm
mdcbigdave
Site Sponsor
Best of luck!!
I will hunt it down in the shed in case you need it.
Dave
Post #408976 Fri Jan 10 2014 2:55pm
Black Bess
yes please. Much appreciated!!
Post #408981 Fri Jan 10 2014 3:02pm
mdcbigdave
Site Sponsor
This is the how to guide from the Disco 3 forum.
It should help.
http://www.disco3.co.uk/forum/topic82516.html
Post #408985 Fri Jan 10 2014 3:37pm
Black Bess
Thank you Dave. I feel much better about it having seen those photos.
I will report back next week on progress. Should be tackling it on Tuesday.
Thanks again
Adam..
Post #408989 Fri Jan 10 2014 4:06pm
Black Bess
Well, I am delighted to report that Black Bess now has a brand new alternator fitted and she is returned to normal.
Thank you Big Dave, for pointing out the technical guidance, it was very helpful. I managed to get the fan hub off without the special holding tool, but I must say, I am going to buy one, since I need to do the cam belts shortly and it will be so much easier with the tool.
Altogether, it took a couple of hours yesterday, which included faffing around with the fan hub and fetching tools from my shed, so it could be done much faster.
I was worried about access, but it is pretty easy once the fan shroud is out of the way, and I like the belt tensioner set-up; very good.
I still have a problem with the sun roof drain pipe on the driver`s side wetting the carpet (at least I am convinced that this is the cause), so that is my next job on the car.
Adam..
Post #409587 Wed Jan 15 2014 9:31am
