Home > Technical > Strange noise on TDV6
fredouille
France 2005 Range Rover Sport TDV6 HSE Java Black
hello everyone,
i have a weird sound, which is there for more than 50000km, so not a big deal but enough to ask here if someone experienced it also...
HSE tdv6 engine 250000Mkm from 2005.
sound comes from the engine left side, a metalic noise occuring at constant rpm, around 2000rpm
it sounds like a "metalic sheet of metal" vibrating (constant rpm, no torque applied to transmission) it stops when i accelerate or release the throttle...
on the other hand, it could also be attributed to a long "psshhhiiiiiiiit" given by a turbocharger blow-off valve...like a air leak generating a long psshhhhhhhhhiiiiiiiiiiiii during the period of time the turbo is not under load.... Question but this noise can stay for kilometers so i use to switch to next gear by accelerating a little bit more...
an other image of this weird noise could be a hydraulic cavitation of a steering wheel oil pump or auto gear box due to lack of liquid but both level have been inspected and OK....
not easy to describe a noise... but have you ever experienced such a whooshing noise?
thanks!
Post #408278 Sun Jan 05 2014 10:45pm
tanloverluke
i've also heard a long "psshhhiiiiiiiit" noise but that's usually coming from the bathroom, given by a blow-off that resulted in a follow-through Mr. Green
on a serious note, i know lots of people talk about the notorious humming noise. here is what comes up when you search for humming:
http://www.rrsport.co.uk/forum/search.php?...rch_time=0
in particular this guy who mentioned a noise that was difficult to describe:
http://www.rrsport.co.uk/forum/topic18974.html?highlight=humming Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #408282 Sun Jan 05 2014 11:37pm
fredouille
thank you tanloverluke,
looks like related to these links, there is 2 different topics.
One is vibrations generated in steering wheel throught the steering rack under acceleration at 2000rpm.
known but never fixed, and it is not what i tried to describe on mine.
other could be mine strange noise, as you wrote, humming noise at constant rpm around 1800-2000rpm also...
- this one could comes from resonance torque converter which could be that.... or a heat insulation metal sheet vibrating but never identified by anyone...
- and other option as i saw in disco forum after submitting my request, could be egr valves (blanked on mine) but can still being noisy somewhere when turbocharger is not sollicitated....
and i learnt that blow-off valves do not exist on tvd6 engine (only on petrol TC like on my past audi TT)
bottom line looks familar to others, but no clear fix identified, even through several pro diagnostics Rolling Eyes
Post #408430 Mon Jan 06 2014 10:24pm
