Home > Maintenance & Modifications > Changing bulbs?
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Changing bulbs?
Changing some interior bulbs to leds.....Not too handy with a screwdriver to be honest....I have change two of the three bulbs (above the rearview mirror) successfully but the fitting for the centre one seems to have disapeared up into the trim when I took out the old bulb....Can anyone advise me the best way to retrieve the fitting...Will I have to take the entire trim off? How does it come off if so?....Advice much appreciated. 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #408084 Sat Jan 04 2014 2:24pm
PEACHY
Can't you pull the connector out with some tweezers Wink 16MY Estoril Blue SVR.............
Post #408086 Sat Jan 04 2014 2:27pm
mad-dafty
Peachy I had a torch to look up inside but I can't see the Censored it must have gone to either side, as I don't know whats up in there I didn't want to poke around too much incase I Censored something up. Confused 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #408088 Sat Jan 04 2014 2:45pm
PEACHY
Nothing but clips & the cables you need - stay away from the front & you will be ok Thumbs Up & I'm pretty sure the cables run from the right hand ( drivers side ) Wink 16MY Estoril Blue SVR.............
Post #408090 Sat Jan 04 2014 3:33pm
mad-dafty
Thanks peachy, going to have another try in the morning. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #408130 Sat Jan 04 2014 8:33pm
mad-dafty
Peachy I ended up taking the map light trim off (which for me was a major accomplishment in itself Very Happy ) The little light connector was inside I stuck it in the hole, gave it a twist to secure and the jobs a good un....all three leds fitted and working well. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #408324 Mon Jan 06 2014 12:50pm
