![]() | Home > Maintenance & Modifications > Changing bulbs? |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
Changing some interior bulbs to leds.....Not too handy with a screwdriver to be honest....I have change two of the three bulbs (above the rearview mirror) successfully but the fitting for the centre one seems to have disapeared up into the trim when I took out the old bulb....Can anyone advise me the best way to retrieve the fitting...Will I have to take the entire trim off? How does it come off if so?....Advice much appreciated. 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Peachy I had a torch to look up inside but I can't see the |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Nothing but clips & the cables you need - stay away from the front & you will be ok |
Thanks peachy, going to have another try in the morning. |
Peachy I ended up taking the map light trim off (which for me was a major accomplishment in itself |
