Home > Maintenance & Modifications > Aerial for remote heating
rigsby
I have recently fitted my receiver and antenna to allow me to use the remote control option of the FBH. It took about 20 minutes in total and works ok. But having a browse on Topix web page yesterday and found the picture type instructions for the fitting which seems to show the position of the aerial as being stuck to the O/S/R window edge. I have just tucked mine underneath the headlining near to the tailgate opening and haven't even stuck it to the body of the car.
Can anybody confirm the best place to attach the aerial or if it even matters? thanks MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #405674 Wed Dec 11 2013 9:32am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Aerial Position
Hi Rigsby, I saw a post that said it should be fitted inside roof liningon roof, But i fitted mine behind the rear quarter panel on the O/S near to roof. It works fine. Thanks for all your previous help on this subject in the past. I had reason to use it the other day. All the cars on the car park of hotel were frosted up and were being scraped. Mine was all meltede and inside was warm Thumbs Up Thumbs Up itisme
Post #407837 Thu Jan 02 2014 11:52am
Bodsy
Site Sponsor
If you order the right part that has the flat aeriel on, then I usually install it behind the C-pillar on the window but not visible.
If you have ordered the aerial with the connector on each end, it should be connected to a module behind the headlining.
Far easier to use the flat aerial. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #407844 Thu Jan 02 2014 2:19pm
harrygh60
RR Remote Aerial Fitting
Hi Bodsy. Yes i have fitted the flat aerial to the C panel close to the roof. The part number for the Flat one is LLR008654.
I didn't know there were two types, But thinking back,when talking to a LR Parts Dealer he said they called it a wire,so i suppose that was the other one Thumbs Up Thumbs Up itisme
Post #407903 Fri Jan 03 2014 8:26am
rigsby
Re: Aerial Position
Ahhh what luxury eh.
Mine is the flat type too and works fine so I will leave it where it is I think. Had it on a couple of times over the holidays and it is great Thumbs Up
Thanks for the info Bodsy MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #407905 Fri Jan 03 2014 9:23am
harrygh60
FBH AERIAL POSITION
What has this link got to do with aerial positioning itisme
Post #407933 Fri Jan 03 2014 1:20pm
rigsby
Post reported as all his posts say the same, let the mods decide MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #407939 Fri Jan 03 2014 2:33pm
