Home > General > Battery Issues?
Mark_TDV8
England 2007 Range Rover Sport TDV8 HSE Cairns Blue
Battery Issues?
Morning All,
Had an issue this morning with the Sport, which I think is battery related - but I would like to check...
When I first picked the car up (Beginning of December 2013), it had a flat battery, so wouldn't start. Once it was jump started it was fine. I drove it home (about an hour) and at one point during the journey It reported a suspension fault which I thought was odd. When I got home, I spent a couple of minutes playing with the sat nav, after which it would not start again - it would hardly even turn over. I jump started it, and it was fine, and using it daily, I have never had any issue with it...
...until this morning. It had sat since Monday evening, but started fine. I left it running for a minute or two, and pulled away up the drive, at which point it reported a transmission fault. Not wanting to have restricted gears, I thought I would turn it off, and restart in attempt to clear the fault, but there was not enough left in the battery to turn the engine over and restart.
Again, I jump started it from our D2, and it ran fine (no faults) all the way to work.
Should I be suspect of the Battery or of the Alternator? Both were replaced in May last year (2013) so are still under warranty.
Opinions appreciated.
Thanks
Mark 2007 TDV8 RR Sport HSE
2003 TD5 Discovery 2 ES
2001 TD5 Defender 110 DCPU
2003 4.4 RR Vogue [Project]
Post #407825 Thu Jan 02 2014 9:36am
Sounds like the battery is dead. Get a new one fitted ASAP. 2012 SDV6 - it's missing a couple of cylinders
Post #407828 Thu Jan 02 2014 10:21am
Paddi
Mark, you could start with the simple things. Connect up a decent smart charger and leave until the battery is fully charged. Then use a multimeter to see if there is a parasitic drain. At the same time you can check the alternator output. Do you have the receipts for the battery and alternator? There are some poor quality items on the market and if the car was just being patched up for sale the replacements may not have been the best. Some reconditioned alternators do not last long. 2008 MY Java Black TDV8 HSE
Post #407831 Thu Jan 02 2014 10:25am
Mark_TDV8
Given that the battery is still under (Main Dealer) warranty, I have taken it to the dealer for thier assessment.
Post #407835 Thu Jan 02 2014 11:26am
RRS Daz
Yeah I've got a similar problem with mine.
If left a few days without been run I can get the park brake fault or special programs not active. Turn off and start it again and it's fine, if I don't the fault goes away anyway.
Alternators kicking out 14.5 volts on idle.
@ rrstdv8 any reason for the "get a new one ASAP"? Is that just so it won't let the op down or you thinking it will wear the alternator out quicker as it's having to work harder?
Post #407838 Thu Jan 02 2014 1:08pm
Both of those reasons - being let down by a dying battery is a pain and I wonder if a dying battery puts more strain on the alternator - an item that is seen as being a weak part in the TDV8 (at least TDV8s seem to be the ones that suffer most from alternator failure).
I had a battery that died on me. I'd put up with it being a bit of a pain for a few weeks before it died. A little while after replacement of the battery, the alternator died. True, there's no proof that one led to the other but... 2012 SDV6 - it's missing a couple of cylinders
Post #407839 Thu Jan 02 2014 1:30pm
rigpig100
2008 Range Rover Sport TDV8 HST Santorini Black
I am having the same symptoms as this
I hope my L/R warranty will cover this !!
Post #407845 Thu Jan 02 2014 2:40pm
RRS Daz
Hmm I wonder too.
Mines had the alternator last year (seen as we are in 2014 now) and I think it's still on the original battery.
Sometimes mine doesn't do a few miles before it's turned off again, normally with lights/heated seats/heaters on too so that's not going to help my case. After it's every other weekend motorway run I get no warnings for a few days..
The op is fine as he has warranty but if a replacement is bought should it be a LR part or any similar spec one do?
Post #407854 Thu Jan 02 2014 5:42pm
Mark_TDV8
Well, I have the car back, and the alternator has been given a clean bill of health, but the battery would not charge sufficiently to run their test! It needs to go back tomorrow to complete the quiescent current drain test before it can be replaced though.
Happy to say that site sponsors Guava in godalming seem to be being very helpful thus far Smile
Daz, I have read a couple of posts on here about sports being somewhat picky about batteries, and that they use a size and capacity unique to them, and not readily available from normal (non dealer) sources, whic means I suspect you will have to go and visit a dealer I am afraid...
Post #407856 Thu Jan 02 2014 6:06pm
RRS Daz
That sounds like a lot of messing about, why don't they just put a battery on and get a first time fix.
It's a good job I've got a mate who works for a main dealer then Thumbs Up
Post #407857 Thu Jan 02 2014 6:23pm
simple1
To change a battery under guarantee, dealer has to perform various tests including current drain switched off plus charging rates. As we know this particular car ( thickly cough) the new battery fitted in May has probably been flat more than charged so foo barred I suspect. I Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #407893 Fri Jan 03 2014 12:34am
MartyRRS
Australia 2008 Range Rover Sport TDV8 SE Alaska White
Finally got around to doing something about having the car sit in the shed for extended periods without flattening the battery due to all those pesky computers that maintain a low current draw. Put a small solar panel (10w) on the shed roof, mounted an old ammo box on the wall to house the solar controller and the rolled up lead (when not in use). Mounted an LED voltage meter to monitor solar output and battery state, a couple of switches for control and job done. Lead plugs into the Anderson socket on the back of the car and when the second battery is full if it is not already connected to the main, it will do so via the dual battery controller in the car. Total cost about $50. Used old switches and wire from stock in cupboard. Pics included. Yep, could have done it better with a 24v panel, MPPT controller, etc, but this was cheap and it does the job. Just sharing in case anyone else may be considering this. Of course down here on Oz we get this thing called sunshine..........
 Regards, Marty
Now: 2008 RRS TDV8; 1975 Rangie ute
Then: 2010 Defender Puma TdCi 110; 1996 Defender 300Tdi; 1997 Disco V8 on vsi gas; 1976 Rangie 4.4l; 20 yrs of back breaking Tojos
Post #407896 Fri Jan 03 2014 4:31am
rigpig100
went to start mine yesterday, checked voltage before cranking it over 10.9 volts, dropping to 4.6 when cranking
. Put charger on for a couple of hours, started it no problem, checked voltage 14.9 at idle, so I guess the battery is goosed, need to check my warranty, not convinced it will cover the battery though.
Post #408299 Mon Jan 06 2014 10:06am
