Home > General (L494) > On/off road pack? |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
I personally can not see a reason for owning a LR without a Hi/Lo ratio box, it's all part of the 'go anywhere' ethos of LR and I think that they have made a big mistake not fitting one as standard..........
Wed Dec 25 2013 9:13am |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 |
High/Low Transfer box is standard on all models except base model TDV6 and Supercharged V6 here in Australia. From what I understand its an option on most models in UK. I agree with you that all LRs should have transfer box as standard. LR have probably sussed out that most never go into low range. RRS P460e
Wed Dec 25 2013 10:07am |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
I think when you start considering vehicles that do not have the High/Low range option then there are better options than RR IMO. I am looking at RR simply because it has the High/Low and is made to tackle something more than blacktop. Presently I own an R50 Touareg, great vehicle, the replacement is a V8 R line with no High Low , which when I start considering my requirements just doesn't cut it. If I was considering an SUV then the R-Line would be my choice in front of the RR. |
Sun Dec 29 2013 12:34am |
Hi/Low is an option on anything without dynamic (so just 2 of the UK model line up). Torque vectoring In the UK im sure comes with the ediff as part of the package. Mike 2014 Facelift Discovery |
Sun Dec 29 2013 5:05pm |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
LR told me at the factory the the latest software on the engines/transmission almost kills the need for the low box on the SDv6
Sun Dec 29 2013 7:21pm |
there will always be a need for low range - it would be worrying if anyone from land rover said that. Mike
Sun Dec 29 2013 8:03pm |
simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193 |
Torque vectoring is standard on SDV6 dynamic, not just the v8's. 2014 Nara Bronze SDV6
Sun Dec 29 2013 8:30pm |
Yes torque vectoring is what makes it dynamic in the UK Mike
Sun Dec 29 2013 11:30pm |
Have changed my order to include on/offroad pack. Find out in May whether it was worth it.... RRS P460e
Mon Dec 30 2013 8:41pm |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
Had a blow out last year..... ay 125kph.......
Mon Dec 30 2013 10:27pm |
I might be wrong, but the stuff that saved your life is the standard kit on all the line in the UK, the dynamic stuff is the stuff that you select and then throw it around corners quickly delaying/defying physics Mike
Mon Dec 30 2013 10:32pm |
TBH.... I keep it on all the time........ and I just think it levelled out some of the body roll.......and made the car a tad more manageable......
Mon Dec 30 2013 10:40pm |
the old sport and the new sport systems are very different - I did use mine a fair few times Mike
Mon Dec 30 2013 10:48pm |
I find the pricing on these electronic options quite high. Needed for safety but the consumer sure is price gouged ! To think that these days nearly all these features come on Korean Vehicles as standard equipment ?? |
Wed Jan 01 2014 12:02am |
