![]() | Home > Faults & Fixes > Limp mode on acceleration |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
Gutted for you Paul. Is there any point talking to the seller about it ? If I was the seller I would at the very least split the bill with you . |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 ![]() ![]() ![]() |
Hi
You could probably get a fuel filter, pipes and thermostat tomorrow if you wanted to try to fix it yourself Mike
Just been reading and it seems, this problem could be caused by a few other possible components as well as the fuel filter, something as simple as a break pedal switch or a steering geometry needs recalibrating, battery low or not charging.
Had a full service today, and asked for the fuel filter to be changed.
Thank god for that! Pleased for you mate now go and enjoy........... |
yes, first time i can actualy feel the TDV8 working properly since i bought it. |
