Home > Technical > EPB
chrisebabes
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
EPB
Just started the car and when pressing the EPB it made a right old racket and now i have parking brake on and fault light, after looking on the site I have tried to lift up the wire cable for an emergency release but its still the same.Cable comes up but brake still on.
Not being much of a mechanic is it now a garage call out !!! any help would be great. Big Cry TDV8 2007 window tints, side steps.
Post #406994 Sun Dec 22 2013 4:56pm
Bodsy
Site Sponsor
Don't use it until you've got it adjusted properly otherwise you'll definately trash it.
Have a look at my brake bible. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #407003 Sun Dec 22 2013 9:42pm
chrisebabes
Thanks for the tip, not moved it at all just tried the switch and the cable will call garage tomorrow TDV8 2007 window tints, side steps.
Post #407009 Sun Dec 22 2013 10:18pm
Bodsy
Site Sponsor
Use the car by all means, but just don't use the epb. The auto box in park will easily stop the car from moving anywhere. Thumbs Up Bodsys Brake Bible
See it HERE
Post #407014 Sun Dec 22 2013 10:49pm
chrisebabes
Thanks Bodsy, hope to get the brake off tomorrow and then call and see my 4x4 guys Thumbs Up TDV8 2007 window tints, side steps.
Post #407016 Sun Dec 22 2013 11:04pm
chrisebabes
update
RAC guy plugged the car into his computer and reset my EPB after another screeching noise it reset and now not going to use it until its been checked out by the garage.
But a bit shocked to find that the wire pull thing did not do the trick though so will get that checked also.
This site is great for pointing you in the right direction and giving spot on advise, happy christmas to all Thumbs Up TDV8 2007 window tints, side steps.
Post #407065 Mon Dec 23 2013 5:02pm
