Home > Maintenance & Modifications > Rear Pads
reid7774
Scotland 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Rear Pads
Hi Guys, needing to replace rear brake pads, seen in bodys brake guide how to do it but I am just wondering, do I have to engage the sequence for the park brake for replaceing the shoes or just if replaceing the discs....Hopefully its just a straight forward out and in then could tackle myself.cheers. 2007 V8 HSE RRS STORNAWAY GREY
Post #406843 Fri Dec 20 2013 7:39pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Just pads will be out and in, you're not touching the disc and the park brake shoes are inside / behind the disc..
have you got a new pad wear sensor? they can be got out if you soak in wd40 first and leave for a while then carefully prise out, unless light is already on, on the dash. 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #406852 Fri Dec 20 2013 9:19pm
reid7774
No have"nt bought them yet, just checked pads yesterday as just fitted new wintrac tyres and noticed they nearly on metal, no warning light on dash.???? 2007 V8 HSE RRS STORNAWAY GREY
Post #406895 Sat Dec 21 2013 12:19pm
Paddi
Maybe I was lucky but my pad wear sensors were easy to remove and were re-used with no problems.
If they've not been serviced recently and you have the time it would be a good idea to strip, clean and lubricate the EPB shoes assembly and adjust them up as it may save you having problems with the EPB later. Not a job I'd want to tackle in the winter though unless you have a nice heated garage Thumbs Up 2008 MY Java Black TDV8 HSE
Post #406978 Sun Dec 22 2013 1:18pm
Bodsy
Site Sponsor
Pads are dead simple, but worthwhile getting a can of brake cleaner to clean it aLl up before pushing the pistons back. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #407004 Sun Dec 22 2013 8:44pm
